Collect Camera Logs
Contents
Collecting camera logs
In case you run into a problem with camera, run the command below at the Terminal as a normal user. After that use the camera application and reproduce the problem with the camera. Once you have done that you can study the log file or send it for analysis.
GST_DEBUG=4 jolla-camera > camera-log.txt 2>&1
The logs are saved into file camera-log.txt.
